dakonthemountain
California Chapter member
I think I may already know the answer to this, but I wanted you experts to chime in here with your thoughts and ideas. I have rebuilt a few in my younger years, but I am most definitely NOT a carburetor guru. Last summer I put a new 600 (or 650?>>>>?? I forgot!) Edlebrock carb. on Burt and the truck was just screaming smooth when I first put it on. Then I recently set the timing (for the first time in a while, it was quite retarded, but I don't remember how many degrees) and now that the timing is spot on the idle is way too high. I can slow down the idle by advancing the timing, but I can't turn it down with the adjustments on the carburetor any more. the idle screw is as far as it will go. My only other thought is to re-jet it to richen it up a bit. Yes? Everything else is factory specs and perfect except the timing and idle, before and after the new carb. Thanks in advance for your replies!
Ford trucks rule!!!
Ford trucks rule!!!
