F250 V10 fuel problems
Had a previous problem with the fuel pump relay which I located behind the radio
Relaced it and it ran fine.
Not getting fuel again so replaced the relay again with no luck this time
Any suggestions?
Is the fuel pump running? Is the inertia switch tripped? Got gas in it?
Theres a tool called a "noid light" that will show the injector pulses if any. You can use a circuit tester between the two circuits, but its harder.
