F250 4WD Intermittent Not Locking In
bowtiehatr
Certified Ford Tech
ok put a vacuum gauge on each line where it attaches to the hub to check for proper vacuum. 15 inches minimun is where i would say it should be. you could have bad seals in the spindle(s)
Yeah, I have been replacing the large seal next to the u-joint. You get debris between the axle and seal, and that causes a loss of vacuum. If you can somehow put no more than 2 or 3 psi of pressure (I use an evap tester) you can spray soapy water on each seal and o-ring (the o-rings are in the lockouts) look for the bubbles.
