F150 4x4 Ride Height
What exact number are you looking for? Diff ground clearance, rocker clearance, overall height or an actual number of the height of where your butt would be on the seat. I have all that for info for my rides...so I could make an educated guess...so just lemme know what you want? I remember JBG had a sectioning of actual heights as well for gen 7 Broncos, I'll see if I can't dig that up.
Ok, then I saw that truck that Ben posted up, the Gen. 7. flareside and wondered how high it was going to be. My estimate is that its going to be about 3.5 feet off the ground.
Well since it's in NC and I wouldn't be the one buying it. I don't want to buy something and not be able to get into it!
22"+12" of lift= 34"+ (7.5" of extra tire above stock/2)=37.75"
Bigger is better because fat chicks can't jump. Remember, low trucks are for guys that can't get it up. And you could always drop it at least 4" by ditching the ghey BL...and then you could probably throw 35's on it...successfully dropping it 5.75".
I'd probably do that. Also, IF I got it I'd probably through some of those truck steps on there and maybe a handle or something. I'm not that tall really.
I e-mailed the guy, if he doesn't respond can you PM him for me?
Sure...if it's something you're really interested in and there's a good chance you'll buy it.
fordman76367
Texas Chapter member
426
4
idk if uulled that from gen7 bronco info or f150 but the bronco sat up a little higher from the factory than the f series i think the f150 is only 2 or 3'' lower tho
