- 14
- 0
I tried to fix it and made it worse
its a 4.0L V6 EFI with distributorless ignition what would cause backfiring Cam position sensor or EDIS pack maybe it had a rough idle then i took the whole intake off and cleaned it upper/lower/throttle body and replaced gaskets now it either revs high or up and down (took IAC off left wires connected revs very high, IAC off wires connected plugged IAC hole it revs up and down or just dies) no movement from IAC mechanism in either case unplugged mass air before new gaskets would clear idle problem but has no affect after new gaskets could IAC stuck open cause backfiring
