89frankenford
Grabber Green Consultant
ok so i have had a check engine light on for a little bit and ive been trying to slowly fix it with no luck.
i scanned the codes again today about 5 minutes ago and these are the codes i am getting. 1 or 2 of the codes are new codes since the last time i scanned it.....
2 digit codes KOEO
21 ECT out of self test range 0.3 to 3.7 volts.
24 ACT sensor out of self test range 0.3 to 3.7 volts.
67 Neutral safety circuit failure.
A/C circuit was on during KOER Self-Test.
84 EGR Vacuum Solenoid circuit failure.
the codes 21, 24 are new now...i actually scanned the truck about 2 weeks ago and it was only three codes 24,67,84 the ECT one is newer and the ACT one is new within the past month or so... for the code 84 i got a vacuum solenoid out of the junkyard and thought that might fix that code but it didnt....i need some help with this. my engine is having multiple random misfires and not getting that great of mileage (down from the 13mpg it usually gets....) im going to see if i can test the sensors in a bit and see what i can find.
(edit) i replaced the ECT sensor about 3-4 years ago and the ACT sensor was replaced 2 years ago just to give a background on those sensors. and i know the code 67 is nothing because i didnt have the clutch pushed in
2 digit codes KOEO
![Confused [confused] [confused]](/old/forum/images/smilies/confused0082.gif)
