- Moderator
- #1
It's time to replace the original coil for the 1983 F250 with the 351 Windsor engine with the DuraSpark ignition. What is the best replacement coil choice? The coil on there now has the slide terminals instead of nut and washer connection, and I have the factory tach option. Most of the coils I've seen will require cutting the factory connections. Thanks, Roy
