I'm just curious Jeff, with you faithfully using DieselKleen and having 130,XXX plus miles, has your EGR valve ever given you any trouble?
Beach, remember, there is a new test that can be performed by the diesel tech to check egr performance. Ford provided us with one in new updates to the IDS
It tests electronic response and physical response. It tests several other related sensor pids as well, that can affect egr performance.
Beach, have your guy select on the IDS......toolbox, powertrain, air management, egr system test. The IDS will give him prompts on what to do. It needs to be at operating temp for it to work (eot over 185 degrees)
