e-brake cable
219
4
CT
Any one replace the E Brake cable on there SD. I park on the side of a hill and use it a lot. It broke today. I don't like using the tranny stop to hole the truck.
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
Depends on what cable broke. if it's one of the rear ones not bad, if it's the one that goes to the pedal it can be alittle tricky.
219
4
CT
it's the one on the pedal
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
The one on the pedal is kind of a pain in the balls, PM me your email address and i'll send the info to you. Im building a shop at my house now so if and when you need some more work done, it'll be a little closer (25miles closer anyways) hopefully it'll be done by june.
4
CT
Got the old cable out. I pull the tip off the cable on the pedal end, had to cut the tip out. Will have to order a new cable.
219
4
CT
New cable install. Thanks for the help.
