Driveshaft
257
5
95 f150 5.8L 254k
Hey guys, I'm trying to solve a vibration issue around 30-35mph. All the ujoints seem fine but there is some movement in the carrier bearing. How much movement is normal?
Thanks!
Best thing you can do is undo the two bolts holding the carrier bearing and lower the driveshaft onto a block of wood , then spin the carrier bearing on the shaft and listen for a rumbling sound ...... if it's more than slightly worn you'll see some movement in the bearing itself.
