Junior I finally got around to getting some screen captures of my Dyno program, sorry it took so long, I kept forgetting about it. Anyways, click the thumbnails below to see a large (beware!) image of what the program is asking for in several categories. It's much more customizable than what I'm showing you but these options are the bare minimum for running a dyno simulation in the program. The company that makes this software boasts within 5% accuracy of a real dyno. I've run it with the baseline specs for a 351 (rated at 210 HP) and it showed something like 205-208HP on the dyno, so I figure it's pretty accurate. Anyways, click the thumbnails and tell me what to input in those fields and I'll run a simulation for you and post results. If the images appear fuzzy and hard to read after clicking on the thumbnail, try clicking on the image after it appears to make it fullsize:
General Layout:
Heads:
Induction Flow:
Manifold Type:
Exhaust Type:
Cam Specs:
It gives those preset values in the pull down menus, but you can alternatively provide your OWN numbers for these things if you've got them (I can't image a lot of people do), such as lifter type, amount of valve lift for intake, amount of valve lift for exhaust, etc etc.
General Layout:
Heads:
Induction Flow:
Manifold Type:
Exhaust Type:
Cam Specs:
