dash lights/parking lights
loudandlifted
bleeds oval blue
198
camdenton mo
I keep blowing a fuse that runs both of those together. I'm 2 hours from home on my way to work and need help. Tried putting a bigger fuse in it to get by still blows it with in minutes. I need help still 2 hours from the job. Heres my cell if anyone has a solution. Can text or call. 5734806631
Never...as in never, never, never..put a larger fuse in a circuit than what is called for. I don't have an answer for your specific problem.
Check for wires shorting out. This might not be too easy on the side of road though. If your flashers work i personally would drive with them on until you get somewhere safe.
Two harness connectors; One directly under the driver's side on the framerail and one to the rear that connects the trailer connections and the rear lights- these get corroded and even water fouled sometimes. Separate them, clean them with a good brush and contact cleaner and tape the joint after reassembly.
