Dang Ashtray
wareagle
War Eagle
1,935
40
Hickory, NC
Okay, looks like one screw is holding my ashtray in, then I can remove it and finally get to working on it where it actually works. I know at one point someone mentioned ball-bearings are used to guide the ashtray in and out.
Anybody have any feedback or tips? Am getting tired of using it as a place to hold nuts and bolts and plan on mounting the USB cable here for my new
retro radio.
Dents have a springy-tab to keep 'em from pulling all the way out
of the dash, don't know nuthin' about Bumps that way.
Why not just drill a hole in the dash for the connection?
And so save your bolt holder. :)
Later you can fill the hole with a carriage bolt, that's what I do. ;)
Alvin in AZ
wareagle
War Eagle
1,935
40
Hickory, NC
Alvin in AZ
That is definitely an option I will consider Alvin...
But that ashtray sticking out like that is driving me nuts... I have been wanting to get that fixed for a long while...
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
4) 354872-S .. Ash Receptacle Slide Steel Ball / Obsolete
GREEN SALES CO. in Cincinnati OH has 428 = 800-543-4959.
^^^When I needed some, I put a caliper on the ones I had, then went to the local industrial supply distributor, told them I needed some steel balls, picked up 4 one size smaller, 4 the size I measured and 4 one size bigger for under $5. I decided I liked the smallest size best.
wareagle
War Eagle
1,935
40
Hickory, NC
They didn't tell you that was a personal problem when you asked for steel balls?
wareagle
War Eagle
1,935
40
Hickory, NC
I know I have seen it somewhere, but could somebody guide me in the direction of documentation that will enable me to fix my ashtray using the ball bearings???
There is a smile in it for you.
Wow that will be, like, so worth it 'cause you're such a sweet little cutie-pie! :)
Have you managed to get the tray out of the truck yet? :/
Alvin in AZ
ps- The balls are 3/8" (.375").
wareagle
War Eagle
1,935
40
Hickory, NC
Alvin in AZ
ALVIN!!!!!!!
Not yet, not a real high priority, as I don't smoke, but was planning on removing it and refurbishing it so I could mount the USB cable for my new retro stereo in there.
Your balls may be 3/8", but mine....
wareagle
War Eagle
1,935
40
Hickory, NC
Okay, I have the ashtray out. Does anyone have suggestions for getting it operable again once I have the ball bearings?
Your Pal,
Steven
