Cruise control?
tylstruck
Canadian diisabled Yuppie
880
34
London, ON
I wished I was a little more m,echanically advanced... at times.
I wonder how easy would it be to add cruise control to an '80 that doesn't have it. Truck is a carburated 302 with ps and pb.
Would I be aaable to add crise control via a few found parts?
Tyl
Brian_B
blank
No clue that far back Tyl. Maybe somone else will know.
I have seen it done on an 89 ranger. The got the underhood parts, the "box" under the dash, and a tilt/cruise column and bolted it all in. The wires for it (under the dash) were already there.
Thats all I can remember from that one.
TexasNomad
FTFS Designated DRINKER!
Tyl
I know they make or made kits to ad CT to older ford trucks I'll looking around and see if I can dig up the link, I have thousands of ford related links socked away.
Brian_B
blank
If you want to go aftermarket...audiovox makes one that runs off magnets on the drivshaft. They are like less than $100.
I was thinking of putting a hiden one on the 56 someday. A friend of mine has one on his 32 (???) streetrod truck.
The instructions that come with them suck, but you can do a google search and get good ones written by people who have installed them.
TexasNomad
That's the one I was thinking of Brian, thanks man :D
But are you sure its audiovox? don't they make Radios and Tvs?
Yes Ty it is quite easy..basically plug and play
I even have a parts list for the retrofit.
The biggest challenge is the brake pedal swap.
tylstruck
880
34
London, ON
Hmmm, I won;t understand this I read the instructions. Seems like a good efficient prodsuct. Many thanks Brian. I will research this tonbight.
Tyl
I prefer the Bendix (OEM) system.
No unsightly parts to look at and the 80's full features
Plus I have all the Trouble-shooting info.
tylstruck
880
34
London, ON
I can't find Bendix's product anywhere?
What is the oem part list?
Tyl
I posted the OEM bendix system above.
The hard things are:
1) Drilling hole in the firewall for the Huge grommet
2) Installing the 2 -piece speedo cable
3) Removing Non-cruise power brake pedal and installing the Cruise Pwr brake pedal
I am looking for my cruise parts list.
Cruise control swap
Parts required listing.
Cruise Control Horn pad and switches
Cruise Control module (Underdash)
Cruise Control wiring (Underdash)
Cruise Control actuating device on Intake
(Carb linkage chain,bracketry,Vacuum pod)
Vacuum actuation device harness
Vacuum Canister and hose to rear of intake.
Brake Booster special for cruise
Brake Pedal & Pedal Assembly
Cruise Control shutoff switch
Cruise control brake light switch
Horn Relay wiring
2 piece Speedo cable
Speed Sensor on Speedo cablefor cruise
Someone can also go to the other site and
search the 73-79 forum the words " Cruise swap" in the message box with my user name
within the last year
It should bring up about 5 threads
what year and model 80's truck is this Ty?
tylstruck
880
34
London, ON
Dennis, it is an 1980 Ford F100 Ranger XLT Flaresider. Blue on blue. Blueberry for now. Brittany, calls it blue b@#$%. She got soo fustrated, the truck did not want to allow her to lock the door shut.
Britz is the beneficiary of this truck, when I go. I would wish to build her a good solid, safe, reliable, practical and fun truck. She'll be the horse maseuse.
Tyl
I'll check my book again for the correct booster number.
You could go with the 82 version that gives you the resume function.
Note: I have most of these parts in my garage.
