- 1
- 0
just picked up a 1993 reg cab f250 with the 351w in it, 5 speed and ttb. pretty decent body for my area, and shes only got a hundred thousand on her. few issues need resolving, such as, shes got a good exhaust leak, which i presume is the manifolds, like every other ford? also, the clutch doesn't want to hold a bleed, fer a few hours you just wouldnt have a pedal, i bled it a few times, now i have enough to drive it but the pedal sinks easily half way to the floor and i get a very very slight grind with a few gears. should i try pressure bleeding it or just replace the slave cylinder? they tranny has a very little whine, probably the syncros? lastely, this is the first fullsize ive owned, and the first solid axle/ ttb ive ever toyed with, the drivers side u joint on the front axle is quickly going, how to i replace them? greatly appreciate it.
