Compressor size?
BigRed1
Here comes trouble...
68
Alabama
Santa brought me this for Christmas - I was a good boy this year! :)
http://www.sears.com/shc/s/p_10153_12605_00916762000P
It is a 33 gal, 1.6 hp, 150 PSI maximum. Says it will provide 6.3 SCFM at 40 PSI, 4.9 at 90 PSI.
Does anyone know if it is big enough (tank size, motor size, cfm) to power a paint gun REALLY WELL? Is it underpowered? Plenty for the job? Overkill?
I hope to give Big Red a new coat of paint and just wanted to know what you all thought.
As always, thanks very much in advance for your time and technical know-how!
Russell
blackhat620
You Had to be There
1,687
150
Arizona
The compressor will be small and underpowered to properly run a standard size spray gun. Most guns require 10+ CFM in the 40psi range. You can do it with your compressor, but expect the compressor to fall behind, and you will have to stop and wait for the compressor to catch up. Depending on the paint you are using and spray environment (ie a booth), you may be able to use a reducer to slow the drying time, thus helping with blending the panel if you have to stop in the middle. Another option would be to paint a panel at a time, or you could add additional storage tanks to your compressor to increase the time before you have to stop and let the compressor catch up.
