Cleveland Lifter-Tru info...
TMI
43
10
What you will see in these pictures is the fixture we use.
This fixture is designed to correct lifter bore alignment to the center line of the camshaft.
Then I used the finishing reamer and partially started a few lifter bores.
I did this to show the ridge and difference from the original bore.
#3 bore lifter bore was really close to reamer hardly touched it. I think #6 was almost as close also.
But you will see the remaining 6 lifter bores are off.
Here you will see #1 lifter bore off center and tipped based on the machining marks tapering off to the side. You will notice that #2 bore is off center, but seems pretty square up and down as compared to #1.
Here is a picture of the block and fixture in our boring machine.
Cool Tim!...one day you will get to see that pile of parts you sold me put together :D
