Charcoal Canister
Hello and good afternoon.
87 F150 5.0L E4OD 2WD XLT LARIAT STANDARD CAB
The Charcoal Canister next to the battery has a 1" hole in the top where I can see the Charcoal.
How does this effect my engine?
Eventually, I am removing the Air Pump and all of the associated plumbing but not until I have finished my current modification.
All suggestions welcome.
Thank you!
Boon
Mine have all been removed, should be fine until you remove it all later.
Well this is a relief. Did you remove vacuum lines and which must remain?
Thank you for your help!
Boon
I took it all out, but you will prob get a ck engine light. You may be able to leave some valves and solenoids and keep the light off.
Hello and good morning!
I found a replacement at the boneyard; $10 and in excellent condition.
Case Closed
Boon
