CB Radio Help
460Trucker
Has the Cat Scratch Fever
2,153
54
Road Salt Hell
Hey guys,
Recently, my CB radio has been interfering with the windshield wipers and when I accelerate. Whenever the wipers move it makes a noise through the static and same when I use the accelerator. Anyway to fix this? It overpowers the radio transmissions from others and I can't understand them.
Thanks for the help,
Subscribing because I've had the same issue and haven't figured it out. My CB is wired right to the battery.
Hooking to the battery by passes any noise filters. You should tie to the stock radio circuit.
I've heard of wind shield wiper noise in the radios but not vice-versa.
Mine does it in the radio too with it hooked to the stock circuit. But I never worried about that too much since I use my cd changer.
460Trucker
2,153
54
Road Salt Hell
M78 It is in the radio, the radio noise is NOT coming from the wipers and accelerator. I apologize for any misunderstanding
460Trucker
2,153
54
Road Salt Hell
What about inline filters? I've been reading about those and how they tend to help cut out the noise. Which kind of filter is easier/more effective?
flareside_thunder
7,812
246
Also, grounding...plenty of ground straps. I fought with alternator noise on mine forever and never did get it 100%. Inline noise filters on the cb power wire would be good as well.
460Trucker
2,153
54
Road Salt Hell
Now I'm not familiar with how filters are installed. Do they screw on like an adapter?
460Trucker
2,153
54
Road Salt Hell
Get some Coax cable and use that as the power and ground directly to the battery.
If that doesn't work try cleaning ALL the Power-Ground related connections
ie:
1)The back of Voltage regulator and the connector for charging,
2) add a braised ground cable from block to firewall
If it is still a problem move your antenna and Make Absolute Sure the antenna connections are clean and secure
Then get back to me before you head to Radio Shack or a CB Radio store
460Trucker
2,153
54
Road Salt Hell
Problem solved!
I went to radio shack about an hour ago to check for inline filters. They didn't have those amongst the significant amount of CB supplies. So instead I picked up a two pack of Snap Choke Cores.
I placed one on the power wire as close as I could to the fuse panel. I turned on the wipers and there was no interference! In fact the entire sound quality was improved and I could actually hear the truckers out on I-91.
Here is the link to the exact ones I bought ($3.19 for two) http://www.radioshack.com/product/index.jsp?productId=3012599
Thanks to everyone for the help!
I'll have to try that. Will it work for my stereo too?
460Trucker
2,153
54
Road Salt Hell
It should. They are for any standard AC power cord. Let me know if it works out.
I will. Hopefully I get a chance to pick some up this weekend. Thanks.
460Trucker
2,153
54
Road Salt Hell
Well this stinks. Now it's back! It's weird how these interferences/periods of silence are so inconsistent.
re-read my earlier post
