Careful where you run wires
mtflat
Flatheads Forever
2,559
147
I replaced the electric fuel pump on my 52 F6. Before finding the bad pump I ran a new wire from ignition to the pump and routed it where I figured it would be safe.
Plowed snow for about 2 hours here and then headed 8 miles up the draw to my son's place. 3 miles of rough gravel road proved I wasn't careful enough routing the wire. Caught between the frame and a metal fuel line, it battered the insulation enough to smash thru to the copper.
Gauges started going crazy and I began smelling hot plastic as I'm flying down a hill. Next smoke started pouring out from under the dash. Oh, xxxx, I'm on fire!! Turned the engine off and coasted to a stop. Fortunately, just the insulation melting off.
Going again in about a half hour with a new wire. Plowed snow till dark.
Be careful with those home repairs.
Dayum. You're fortunate to get the truck running again after an incident like that. Did you melt any wiring in the main harness?
Bob Ayers
North Carolina Chapter member
1,474
111
Durham, NC
You didn't use a fuse?
Brian_B
blank
I bet you were more careful of the routing the second time. Good to hear all is well though.
Just one more reason I hate electrical stuff. :(
Oh...on a side note: We want to see pics of you plowing with it. I think that would be cool.
TexasNomad
FTFS Designated DRINKER!
After my brother rewired his 64 Chevy with a Painfull wiring harness and we turned the thing on kaa blooy! no more wireharness
mtflat
Flatheads Forever
2,559
147
They don't use fuses - 48-52 use a circuit breaker instead. That's why the ammeter was dancing back and forth.
No additional damage to the main harness - it wasn't bundled in with the rest of the wires. However, the original wiring is so brittle that if you bump it hard the insulation falls off. I spent a lot of time taping bare wires.
I have a new harness but this truck is destined to become a parts truck for two others - my 48 F6 and 52 F2 so I'm trying to limp it along until spring.
I'll try to find a couple of pictures from last winter. I had them posted on the other site for awhile.
Brian_B
blank
If he is going to part it out in the spring...not a big deal. Just keep a fire extinguisher in it for now. A big one!
Mine has been re-wired from front to back. So far...no wiring issues, but it is a home made harness. It is stock as far as how evcerything is wired.
At least that old rotten brittle cloth covered wire is gone.
I might have seen the pics over there, but I certainly do not recall them. If you find them...I would like to see them.
Bob Ayers
1,474
111
Durham, NC
I don't know about his, but mine does not have a fuse panel. I was told the guages on mine have a fuse hidden under the dash somewhere. Other than that...I am not aware of my truck having any. 'smiliedoh'
I was thinking of using an inline type of fuse:
TexasNomad
I took out the original ignition harness on my truck so I have a bunch of extra fuses that I've plug stuff in to :D
When adding accessories or extra wiring to your truck, the easiest way to remain safe is to use an auxiliary fuse block. I did this to run things like my flashlight charger, aux gauge, etc.
Just has 1 hot input from the charge post on my alternator and then 6 fused outputs for accessories. They also make them in bigger sizes with more outputs.
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
If i add anything more to my truck that will be on the list...
I have a facination with flashing lights, and it just so happens there are millions of them waiting to be put on my truck courtesy of evil bay...
