LEB Paul
I like Broncos
I have a holley 750 double pumper vacuum secondary on my basically stock 460, when driving it over heats and when I pulled a plug after it got pretty hot it looked as if it were running lean. Timing is good and it will sit at 170-180 at idle for as long as it sits. So we decided that the secondaries were probably not functioning properly.. so pulled the air cleaner blip the throttle or open it up hard.. no fuel squirting in the back of the carb.
I'm fairly sure it is not a vacuum issue, but I will go over the lines and check to make sure the un used ports on the carb are blocked off. Assuming it is not a vacuum issue, it appears it is time for a rebuild. Does anyone know where I can find a kit to convert it to mechanical secondary and a good over haul of the carb? I've not worked on carbs before so I don't know what I'm looking for when looking up the different rebuild kits on summit or whatever.
So to recap
-can someone show me where to find a kit to convert this carb to a mechanical secondary?
-and which rebuild kit would one suggest for this carb?
Thanks for any help
So to recap
Thanks for any help
