Can someone identify this oil pan?
I've got it on my motor now but would like to know just what it was from, the numbers on the pan are:
4 0489A
E7HE 6675
Thanks.
How you verify that "H" first ..because that should be a climate control design related part.
It doesn't seem correct.
This is on a 460 but looks like a large truck pan (holds about 9 liters). I'll have to crawl under again and see if I can clarify the "H" Mil1ion.
BKW
Ford Parts Guru
1,896
118
Simi Valley, CA
H in the part number prefix.
H refers to heavy truck in the parts prefix.
H prefixed parts also appeared on light trucks in some applications, but not this one.
E7HZ-6675-B .. Oil Pan (replaced: E5HZ-6675-A).
Original application: 1985/89 (EDIT: till 3/28/89) 370/429 engines as used in F600's etc.
Thank you very much, that was just what I was looking for. You also saved me from crawling under the beast tonight :).
