Camshafts
Mr. Stroker
CASE IH
3,121
67
Michigan
Anyone know the stock camshaft specs of these 351 EFI's? And also what is the specs of a camshaft out of a 95 Cobra mustang that had a EFI 302?
good question if anyone knows... I'd also be interested in figuring this out. When my 351 dies, I'll have to rebuild it eventually too, and I think it would be silly to put it back together stock... :devil:
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
Camshaft Engine Lobe Lifta Camshaft End Play Camshaft Journal to Bearing Clearanceb
Intake Exhaust End Play Wear Limit
5.0L (302 CID) 0.2637 0.2801 0.001-0.007 0.009 0.001-0.003
5.8L (351 CID) 0.2637 0.2801 0.001-0.007 0.009 0.001-0.003
a Maximum allowable lift loss — 0.005.
b Service limit — 0.006 maximum.
Cobra
Lobe Lift
Intake .278
Exhaust .2780
at zero lash .4420
Mr. Stroker
CASE IH
3,121
67
Michigan
Thanks dave.
Mr. Stroker
CASE IH
3,121
67
Michigan
Ok now that i know. I heard that the LSA should be above 114 for the SD systems. The reason why im asking is because my buddys cobra 302 got blown up, and im wanting to see if the camshaft is still good or not.. Now If i have a chance to get that cam will it work?
