C6 Shift kits
The bottom one would be better one if you want to keep the trans from burning up in a 4x4 application.I say because you would have more pressure applied to the bands with the manual shift upgrade.Just depends on how heavy you foot is and what its being used for really.top one is good for street use and mild offroad use.Manual shift is fun to play with mud slinging and tire smoking.But thats just my opinion.HOPE THIS HELPS
Ok...but what's the difference in manual shift. With the stock set up I can already manually shift in to 1st or second at the column. So I'm confused.
Its the slip that you would get in between shifts. The manual shift applies more pressure almost making it a instant shift with no rpm jump between shifts.Hard to explain but very affective in how it works.
Thanks...I did a little more research and I get it now.
FWIW...I put my faith in a chain store (the O'reilly's I'm becoming more and more comfortable with). I got the PN from summit, called O's, they said they'd price match ($7 difference) and they'd have it in tomorrow afternoon. Now I don't have to pay $10 in shipping, wait 3 business days or worry about shipping screw ups. Now let's hope the chain store doesn't some how screw this up.
Good luck with that:)...which one are you going with the regular or manual kit?
I just decided to go with the regular one. At this time, I have no real use for full manual, and this is more or less a band-aid than an upgrade.
