C6 Crossmember..
F 150Cobra
"Wild HoRsE" Got Torque?
3,642
104
Aruba
is it the same from the M5OD? if not? who has one?? i need one
All I got is one for an E4OD '91 Bronco.
Need pictures of it?
It looks like new (!) but is ugly as anything the way Ford shaped it. :/
It goes outside the frame on the passenger side and it dips down to
go under the second cat.
The one from the parts truck, that came with the ZF, bolted right in.
The holes were already in place.
Alvin in AZ
F 150Cobra
3,642
104
Aruba
sure post up a few pics.. i gotta ask around to see wich one i need to use.. or fab a custom one
http://www.panix.com/~alvinj/file12/e4odCM1.jpg
http://www.panix.com/~alvinj/file12/e4odCM.jpg
See how it dips down?
And the right side bolts to the outside of the frame?
(July '90 so a '91 model Edweena Bauer E4OD)
http://www.panix.com/~alvinj/file12/zfCM.jpg
That's the crossmember from the '90 F250 parts truck. :)
See how crooked it is, bent back like that?
What the heck for? :/
Makes it so when it's unbolted it twists because only the rubber
mount to hold it straight. So no sliding the transmission "back
and forth like its on rails :)" with the ZF, like I can the T18. :/
This is what it rests on in the front while "on rails"...
http://www.panix.com/~alvinj/file12/guidepin.jpg
http://www.panix.com/~alvinj/file12/guidepins.jpg
Alvin in AZ
ps- Sorry it took so long, a "low pressure" went by and kinda
had me messed up a little. ;)
pps- "scaled" the E4OD pics too small at 500, gonna re-scale
them from the originals to 750 or so.
KdPate
After Hours Garage
Just go to the junkyard and get one. Will be much cheaper than fabbing one up......:rolleyes:
F 150Cobra
3,642
104
Aruba
i just learned that the M5od and C6 and AOD uses the same crossmember... soo if thats the case... im lucky :)
haha we have junkyards but not many fords in them..
