- 4
- 0
I have a 94 EB FSB with a 5.8. It has the all to common pinging, missing, and rough idle with the spout connector in. Pull the spout out and it runs smooth with none of the above symptoms.I have the BLACK CCD TFI. I've replaced the EEC-IV, TPS, PIP, ant TFI (used one, but advertised at good), EVR, plugs, wires, dizzy, coil, and fuel filter. I've seafoamed 3 times, cleaned the IAB, and dressed up all my grounds. All wires from the EEC-IV to the TFI, and PIP have checked good. The timing is set at 10* BTDC. I have checked the balancer timing marks against piston 1 TDC to verify that it hasn't slipped. I have routed and re-routed all my plug wires to eliminate crossfire. I know my way around electrical troubleshooting, but this is really humbling me. I have a really nice OBDI/II scanner that you plug into a laptop and watch all the sensor readings while idling or driving and record them. I have taken some recordings and have some screenshots of the data, if you'd like to check them out. Someone, please help I'm pretty sure i'm developing an ulcer due to this truck. Thanks.
