Brakes
Blade
Backwoods boy
4,657
225
In the boonies
Hey guys... jw but 80% percent of the time the brakes on my ranger continuously suck air when you depress the pedal, then other times it works fine. i still have brakes when it does it, i just have to press the pedal harder than normal. any idea whats wrong???
I've got the same thing with my f150. The brake booster is faulty, allowing an escape of vacuum whenever you press the brake pedal.
1,320
82
That is weird... Are you sure the bleeder valves on the calipers and brake cylinders are closed and functioning correctly?
