wareagle
War Eagle
I've been around tools for awhile, seeing a lot of weird ones while a mechanic in the Marines, but what the heck kind of tool do you use to screw in the bolts that hold the seatbelt harnesses to the frame?
Hmmm... I don't know but my '75 has two in the door strikers.Went to Northern Tools and looked at their Torx sets.
Besides the seat belts, where else on a 70 F100 would Torx bolts be?
One bed bolt on my '75 was a #4 Phillips if I remember the size right.
It's because of the mid-ship tank. For some strange reason the
factory decided it needed that special bolt there, I've swapped it
out with a regular bed bolt. Quicker on the line? ...I'd guess.
What I noticed on my '91 Bronco the Torx bits (for the most part)
are #20 #30 #40 #50.
Answer: "Like, look, or something?"
Alvin in AZ
ps- Ford used some Loctite or Loctite-like stuff on many of the
bolts on the newer stuff and it can be a real problem, no kidding.
#1 Best is to use heat and #2 is chlorinated brake cleaner. WD-40
PBBlaster, LiquidWrench -seem-to make it worse instead of better.
What I've notiiced is the tri-lobular type bolts tend to have that
dangged glue on them and yeah, can cause trouble sometimes
and not others. Some of the seat belt bolts are tri-lobular.
I've got Eklin sets that fold up into a handle and others but for the larger ones
I was lucky enough to be near to "Kent's Tools" in Tucson so bought my larger
ones for less money than a set, used, name brand, one at a time.
Just happened to find a 3/8" drive T-50 on the street last week. (GreatNeck)
Alvin in AZ
