Body Lift
HazzardMadWolf
Go Fast Turn Left
170
Western Ohio
I am thinking about a body lift. Not sure what all is involved. I know the kits are pretty cheap, but it seems like all you get is the blocks and hardware for them. What else do I need. I am guessing i need to raise the motor or replace the fan with electric.
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
Everything you should need will be in there. It will have a filler neck tube extender, fan shroud lowering kit, usually front bumper and sometimes rear bumper brackets. You will have to keep an eye on your wires as you lift it you may have to cut them loose off the frame and re-tie them in a different location. Performance Accessories sells a pretty good one.
HazzardMadWolf
Go Fast Turn Left
170
Western Ohio
most of the kits I have looked at do not include the fan shroud or filler neck extender... Where do I find the kits u are talking about?
lil_dq
Let 'er eat boys!
6,933
265
Union, MO
4,038
135
Trinity Tx
Yes I know its from there But its worth the read...
http://www.ford-trucks.com/forums/724378-body-lifts-the-why-not-and-the-how-to.html
Ok. Given recent discussion I felt it best if we had a thread discussing body lifts, the merits of them, and if you are going to do it, how to do it in a safe manner… and discussing how to and why not do them in an unsafe manner.
This way if in the future threads come up regarding them (body lifts) we have a simple direction to answer most questions.
Why would you want to do a body lift?
The answer to this is pretty obvious, you want the body to sit higher, be it so that it is for looks, or you want more clearance for larger tyres etc.
What are the implications of performing a body lift?
1. Higher Centre of Gravity – that is pretty obvious, but needs to be taken into consideration when considering what tasks your vehicle is performing and how it is driven.
2. Moving controls/wiring etc. that are mounted, or get access through both the body and the chassis frame rails. (Transmission shifters, the main wiring loom etc.)
3. The most serious (as it has serious safety implications) is the fact that now the body, and all that it attaches too will now not be sitting in their standard locations, and you have the 2 largest, heaviest and critical systems of a truck (the body and the frame) separated. More on this further down. This has significant impact under acceleration/braking, loading and more importantly… crashing.
4. You need to make sure that it does not effect anything that is packaged around the body/chassis. i.e. engine clearance etc. On most Ford Trucks this is not a significant problem.
Now, it is almost always advisable to perform a lift using the suspension and its mounting hardware and/or axles (if applicable) and I strongly encourage anyone to research doing that before contemplating a body lift (assistance on this can be gained in this forum).
Now, despite all this you would still like a body lift.
How should I go about undertaking it?
Bear in mind a Body lift has much greater impact than the apparent "ease" of performing such an operation suggests, and it is not something to be undertaken lightly, because it's cool or anything else. If in doubt ASK!
Critical components and things to watch out for –
1.Bolts.
a.Use nothing less than grade 10 bolts, this is a non-negotiable item. You are substantially increasing the load in the body attachment bolts.
b.Use external drive bolts, preferably with a flange on the head
c.Use a coarse pitch thread. (either UNC, or course thread metric)
d.Use the largest diameter bolts possible. The aim of doing a "good" body lift is to maintain the body attachment bolts in pure tension as they are standard, the reality of it will be you will induce SOME bending, as such you want the greatest diameter possible to deal with that.
(see simple diagram for difference between tension on the left and bending on the right)
To illustrate the importance of this, get some wire, try pulling it apart to break it.
Now try bending it. Is it easier to bend, than it is to pull it apart?
Now, get a large diameter bolt. Try bending it. Is it easier to bend than the wire?
e.Select the right length bolts that go right through the body attachment points on both the body and the chassis (i.e. DO NOT tap a thread into two ends of a spacer, and clamp it from both sides). Allow at least 6 threads between the last screw thread and the first engaged nut thread, and ensure at least 2 threads between the tapered thread section and the last engaged nut thread. See diagram below.
f.The bolt needs to be corrosion resistant. Magni 560 or 565 coating is preferred.
2.Nuts/washers
a.Use a flanged hex nut.
b.Use washers on both the bolt head and the nut side. This is to provide clearance for the bolt head fillet and to provide greater stress equalisation and transfer through the spacer.
c.Use a spring washer on the nut side, between the flat washer, and the nut..
d.Ensure, like the bolt, that the nuts/washers are corrosion resistant (again, Magni 560/565).
e.Ensure it is also Grade 10!
3.Body spacing hardware
a.PAD AREA! To prevent the bolt being in significant bending, ensure that the spacer you are using is as large as it can feasibly be in all directions. This is absolutely critical.
b.Ensure that it is flat, and sits flush with both the body and the chassis.
c.Ensure that the hole clearance diameter in the spacer is no greater than 1mm (~1/32") in diameter than the bolt size to distribute stress throughout the spacer (and bolt) in the best manner possible.
d.Ensure they aren't a generic item (don't use hockey pucks or anything similar… please!).
e.The material needs to be as stiff as possible, don't use rubber, wood, aluminium or anything similar. Make sure it is at a minimum out of mild steel, exotic steels/materials that you can get your hands on are only a bonus!
f.They need to be solid. Not RHS, not I-beams, SOLID machined steel! This ensures the best transfer of bolt tension.
4.Fitment, engineering practices, and other worthwhile info.
a.Ensure the areas, and all hardware are wiped clean of any dirt/grease/oil etc, and are free of any surface imperfections (bubbled paint, rust etc.) before commencing.
b.Use loctite threadlocker or similar on the thread of the bolt..
c.Torque. Given the application, its not appropriate to TTY (Torque to Yield), as if you get airborne, or experience significant force attempting to separate the chassis/body, your bolts will fail. Torque to ~75% of yield torque.
d.Tighten from the nut side only.
e. Take time during and after fitment to check for things such as:
i.Cross-threading, was it excessively hard to torque from the start?
ii.Correct fitment and alignment
iii.After 1 week of standard vehicle use, re-torque nuts.
f.DO NOT stack blocks/spacers. It adds undue variables, and reduces the likelihood of the joint being a true friction-type joint.
g.DO NOT stack frames. What appears to be a simple solution, means significantly longer bolts, poor transfer of bolt tension, and a plethora of other problems.
h.Attempt to keep your body lift as small as possible.
Now, body lifts have their applications – I even know of at least one instance where they were used by Ford on production vehicles, however they are something that should definitely be treated with respect. Failure to do so can result in serious consequences, potentially up to the death of yourself, your family and other road users. This basic guide here is not a be all and end all document either, but it assists in preventing the most common type of failures I can foresee.
Ok guru's, have I missed anything?
bigun72
XLT= Xtra Loud Truck
306
8
Jackson,TN
i kno this old , but i have never had any problems outta bodylifts , i dont understand why everbody hates them......if they were unsafe or anything they wudnt make them JMO
