- 14
- 0
i have a 97 ranger that i had tires put on and an alignment. the shop repacked the wheel bearings and about a yr. later the right bearing broke. The shop said bearings do go bad it not their fault. Okay it's possible but i believe more to do with the 18 yr old doing the work. They replaced everything on the right side the 2nd time (spindle,rotor,bearings) but apparantly not the ball joints as i found out today ( they reused the old balljoints on the new spindle)
. I think the bearing went but they looked at it again and said no its the lower ball joint on the passenger side and the upper on the driver side coupled with a broken carriage bearing on the drive shaft. Could that cause the sensation that one tire is repeatedly running over a large stick even at a crawl it does that. i believe the wheel bearing is the cause. either way they reused a pressed in balljoint that cant be right.
