92 Flareside: redo the head gaskets again, Remove EGR system, Ball joints, shocks, rear leaf springs, add traction bars, get new radio, install new speakers....
98 Exploder, fix the EGR system, and another oil change is coming up quick, second in 1 1/2 months.... racking up the miles in it..
Bronco fix rear window motor/ regulator, rear window key switch on tailgate, pcv hose, air filter, liscence plate bolts that are stripped out, stereo and new speakers, get some good door panels from DC and put my wood grain trim on em, swap to a 4 bbl in the spring get new quarter panels when were ready to paint it, put some kind of under coating on floors in spring cause they only have surface rust so far.
86 Re seal intake in the spring, get some brown seat covers, find a place to mount the cb and antennas.
72 pull all body parts off the frame and fix rust, find a better bed, find better front clip, re do the top end of the 410 with adjustable rockers and a new cam, paint after rust is fixed.
85 For sale.
Jeep get it fixed good enough to beat the hills with and just tow behind a truck or the Bronco.
