Anyone Do U-Joints In A 3 Joint rear shaft?
So I am doing all my u-joints on the bronk before plow season starts. The axle ones I did when I did the ball joints. The front shaft ones were seized. They were cake. Went to do the rear u joints and it has the 2 u joints at the top with the ball and socket. They are like all attached together and seem like its not ment to come apart. Didnt feel like not being able to drive home from work so I just did the bottom for now. Anyone do em ever?
Ah yes, the double-cardon joint at the front of the rear shaft. You can do it yourself if you have a vice to hold everything while you work. The ball and centering spring need to be held in place once one spider has been installed so you can get the second one installed without everything falling back out of the carrier.
I've done one...and for me, it's well worth paying someone else to do it. Really not all that difficult, but my patience and lack of fine motor skills tells me to cough up the $50 in labor it'll cost.
Ok, ill have to do them then.
Bloodhound
Oilfield Trash
I tried to do mine myself in the jeep. I messed up the cup and had to send the shaft to a machine shop. Next time I'll send it to the drive shop.
For the headaches its simpler to let the shop do it. Besides, its not like you will have any down-time with the Bronco while the rear DS is out. Just put the t-case in 4-HI and have FWD for a few days.
Yepper i agree let the machine shop handle the Job.if you do them yourself,make sure you position the grease fitting out to where you can grease it,many make this mistake.
