AMSOIL Fuel Saver Package!
384
Want some better mileage out of your vehicle? Also want better protection?
We have you covered! We have Diesel Options as well!!
Signature Series Engine Oil-Being a True synthetic, it helps lower temperatures in the engine bay, reduces friction, and lubricates better than other oils on the Market.
https://www.amsoil.com/shop/by-category/25000-mile-oil-change/?zo=5224678
EAO Oil Filter- Helps keep contaminants out of the oil, allows the oil to continue to protect and lubricate the engine for longer periods of time.
https://www.amsoil.com/shop/by-product/filters-and-by-pass-systems/?zo=5224678
Signature Series ATF Transmission Oil- Also being a true Synthetic it helps transmissions shift more smoothly, opperate at lower temperatures, and extend Transmission life as well.
Severe Gear Differential Oil- Reduces drag and friction in the differential to better transfer power to the wheels.
https://www.amsoil.com/shop/by-product/gear-lube/?zo=5224678
Performance Improver Gas Additive- Helps clean up the fuel system, clear clogged injectors, and clear any condensation in the gas tank.
https://www.amsoil.com/shop/by-product/fuel-additives/?zo=5224678
Coolant Boost- Helps better transfer temperatures from the cooling system, reduces temperatures in the engine compartment, also helps reduce any buildup in the cooling system of any trash and contaminants.
http://www.amsoil.com/shop/by-product/other-products/antifreeze/?zo=5224678
f
