Ridgerunner
Can the air pump or smog pump as a lot of people call it, be turned into a small air compressor that runs off the engine?
I don't believe it can because it's a vane-type-fan instead of a pressure-pump.Can the air pump or smog pump as a lot of people call it, be
Huh? 8/I guess I could pull it off... but it's a lot of work.
I didn't forget. If I forget (or I'm wrong) I'll jump at the chance to fix it.I have pulled smog pump off a 85 before and most people seem to forget
they have to plug the back of the heads with a pipe plug. Rather hard
when you still have the engine in the truck.
