- 2
- 0
Hi all, new to the forum and totally stuck. 88 F250 with 460 efi. Had to change waterpump last weekend and discovered that the air pump pulley was really wobbly. Considering that the air tubes were rusted gone and the previous owner has already removed the OEM CAT, I took off the pump and started disconnecting the tubing. There was supposed to be two vacuum solenoids to remove the lines from, but I could only find one. The EGR is still hooked up. I have looked and looked and I cannot for the life of me find any evidence of the thermactor tubes in the back of the heads. Maybe the previous owner already plugged it and removed one of the vacuum solenoids? I can't even see back there but sure can't feel anything either. Now my truck runs bad. Didn't before. Loping rough idle, sputtering and popping through exhaust at part throttle. Just bad. Can someone please offer some help to a novice? Thanks in advance.
