RangerPilot
Boom Shaka Laka
'98 Explorer XLT, 4 door, driver and passenger air bags.
Let me preface this by saying last night I was putting driving lights on my grille guard and messed with what I thought was a plastic piece in place of a stock sensor for maybe the 4WD or something.
It looked JUST like an oil pressure switch, except the whole thing was cast out of plastic. I messed with it a bit then left it alone except for running a wire next to it. It was located on the driver's side of the header panel, about halfway up the A/C condenser. I also tapped into a grey/orange wire that was supposed to be power for the high beams (but wasn't apparently).
This evening I started the truck, air bag light came on normal when I turned the key to run. After the truck starts, the light goes off, then flashes once, then twice in succession. It repeated this cycle I believe five times before going out after the double-flash, then illuminating constantly until the truck is turned off.
Did I mess with something bad? Make a bone-headed mistake? Tap into a wire for the airbags or airbag light instead of the high beams?
Thanks for any assistance.
