Ahem! cough cough HELP!!..........
TexasNomad
FTFS Designated DRINKER!
I'm hooking my fuel pump up with a universal relay kit and every thing is going smooth until I got to this part...
Attach the 18 gauge YELLOW wire to an independent (Off/On) fuel pump switch, which is powered by a fused source
Yeah... well thats easy enough I can do drunk wich i am .. BuT! what size fuse?
why the hell do wthey have to be so damn vague about these things, do I just start throwing fuses at it.. geeses its this kinda stuff that get on my nerves..
Any help will get a rep :D
http://www.jegs.com/InstallationInstructions/500/555/555-10564.pdf
Hey Tex....any fused power source will do...all it is doing is operating the coil of the relay....try to find something that is powered after the ignition switch is in the "run" position. If you wanted to, you could run a fresh wire from the battery with a 10A inline fuse to a switch hidden under that dash that turns the relay on/off...I know a few guys that do that to deter theft.
