ABS & Parking Brake lights...
Truckin4life
Texas Chapter Leader
9,037
San Antonio, Texas
Both the ABS and Parking Brake lights are on...
But the parking brake is NOT engaged, i never use my parking brake...
Whats goin on?
The ABS light comes on just after i start the truck, the Parking brake light is usually on when i start but when i take off quick or go from rolling back wards to taking off it will go off for a minute, but then comes right back on....
Any suggestions guys, kinda got me stumped...
Not trying to insult you, but I've seen this happen with low fluid. Beyond that, possibly a brake switch.
Truckin4life
9,037
San Antonio, Texas
You think maybe dirty fluid ben?
I need to flush it out, i know that much...
Ill try to pull the codes in the morning before i leave...
If not for sure when i get back.
Couldn't tell ya Don...but I've seen nasty fluid throw those lights before...so it's a possibility...and probably the easiest/cheapest thing to deal with.
973
11
mine did the same thing when i was low on fluid, top it off and you should be ok, if not, you probably have a bad float in the Master
Truckin4life
9,037
San Antonio, Texas
I looked at the float and the fluid was over it, but it didnt come up, so i tapped it with a piece of wire and it came back up, im just thinking it got hung up... But either way lights went off...
Thanks guys, reps to the both of ya.
973
11
glad to see you got it fixed!
Sparky83
Virginia Chapter member
5,571
226
Norlina NC
yup glad to see you got it fixed... first time ive heard of them having floats in the reservoir... guess theres always a first time for them to make interesting things...
Truckin4life
9,037
San Antonio, Texas
Its a dummy light for when you fluid gets low, lets you know its time to change brake pads... Your fluid gets lower as your pads wear out. Or you have a leak. Either way its pretty nice i think.
Sparky83
5,571
226
Norlina NC
yeah ive seen them do sensors for the fluid levels before.. just a first for a float type one... ive never had a vehicle before that the pads would wear out so much that theyd trip those sensors.. seen it a once when i was bleeding before and forgot to refill while i was bleeding lol... only other time i got the light was because of firestone.. (never let them touch your brakes).. had the system flushed and the dimwits left the bleeder valves partway open... got halfway home and my brakes quit working...
Truckin4life
9,037
San Antonio, Texas
I haven't seen it go off about pads either but i dont mess with my brakes, i do know its about time though, would rather replace pads a little early then wait to long and not have brakes...
973
11
your ful level is measured with a float too lol..
and its really not for pads as they have wear indicators built in, more so for leaks, especially slow ones that you cant feel through the pedal
Sparky83
5,571
226
Norlina NC
agreed... im being a bit lazy with my stang though... its been sitting alot lately and last time i went in for inspection i got "warned" on them.. (they use a 3 color system at ours, green = good, yellow = warning but still kinda good, red = fail/replace)... still havent done them yet... figure at 60 bucks a pair they can stay on there till they tell me they need to go.. do know i need to get the rotors turned though when i go to do change them... some reason driver sides decided its not going to wear properly... hubs look like they have the rings of saturn grooved into them...
Truckin4life
9,037
San Antonio, Texas
this is true, but brake systems are designed in that when the brake pads wear down the fluid level goes down. Alot of people will top it back off then when they go to change brakes they have loads of extra fluid usually spilling over the top. It was something i was taught when i was working at the transmission shop, if the brake fluid is low check the brake pads for wear.
973
11
yeh, true, but what im sayin is ive had cars that were metal to metal in the shop and the lights werent on.. lol... it seves a few purposes, who know what exactly they ment for it to tell you
Truckin4life
9,037
San Antonio, Texas
Yea that is also true... I use the fluid level as an idicator once it start to get a little low i start checkin my brakes more often... Just something to make it easier for me.
