ABS light
After replacing my rear brake line and bleeding the system my abs light is now on. But it has just came on. I wasn't on when I took the truck out for a test run. The brakes feel spongy still. I'm thinking of bleeding the front lines again.
F150
easy
512
10
upstate NY
You need to bleed from the farthest point from the master cylinder and work forward. R-rear, L-rear, R-front, L-front. Make sure the master doesn't run low on fluid. ABS shouldn't come into play here.?
I can't remember if your truck has rear-only ABS or 4-wheel.
If it's rear-only, like my '97, just bleed the heck out of the rear brakes. You'll stop getting bubbles for a while, but keep going until you push all the air in the ABS unit all the way back and to the rear wheels.
Never dealt with 4-wheel...can't remember what you have to do for that.
racsan
4xford
379
15
central ohio
some 4 wheel abs setups (primarily g.m.) require some specaility stuff to do a bleed job with. my '93 was rear abs only. im thinking 4 wheel abs didnt happen until the gen 4 (1998) when ford did away with twin I-beam/ttb, went to torsion bars and unit-bearing front hubs. i could be wrong about that. i agree on pushing more fluid through the rear lines. it took awhile to get it done on my truck when i had to replace the rear line going to the back axle from the proportioning valve.
