99 Mustang -- Same rear axle as mine?
Got a guy who contacted me about the 3.55 gears I've got for the Ford 8.8.
He's asking me if the gears are compatible with his 99 Mustang... Does anyone know if they were still using the 8.8" rear axle in 99?
TheRoadVirus
High-Steppin' Mo-Sheen
2,461
31
Ontario, Canada
I didn't know if the spline count would be the same on that 8.8 as mine...
Though I guess it wouldn't matter for a gear swap :rofl:
surewhynot
Rep whores make me sick
13,843
821
Florida
The axle spline count wouldn't matter on just the r&p. The pinion spline is the same. I'm assuming it would work, but that is just an assumption.
A 99 Mustang GT should be a 28 spline 8.8" rear end provided it's not a cobra or higher. The V6 uses a 7.5" rear end. So provided it's a GT the ring and pinion should work provided he uses his same case and spiders. I may be wrong on all that but here are the sources I used.
http://forums.stangnet.com/743163-31-vs-28-spline-vs-7-5-vs-8-8-vs-9-a.html
http://www.ringpinion.com/PartCats....Mustang&Side=Rear&DiffID=28&DiffName=Ford 8.8
Hope that helps ya Skan.
Great info. I'll confirm with him that it's a GT. If it's a cobra then what rear end is he using?
If it's a cobra I'm assuming it should still be a 8.8" with 31 splines instead of 28. If that's the case then why is he wanting 3.55s?
He said he's got 4.10s and wants to swap to 3.73s or 3.55s... Sounds like someone's wallet is getting too light :D
What would you guys ask for an used 8.8" ring and pinion set in PERFECT shape? Bout 100k miles on 'em and nothing to show for it. Factory gears, Ford logo stamped on em.
Hahah, I asked him $70 since he's asking me to separate the whole set of 3.55 r&p + carriers for front and back.
He's free to negotiate from there :)
Cope&Dies
gab-d a snaks
17
your truck has the same rear as a mustang?! HA!
