My ranger 4.0L V6 has been idling rough and dieing when stopped. it would clear up if i rev at about 1000rpm but wont idle itself. i was told it was upper manifold gasket so i replaced the set upper/lower/valve cover gasket since valve covers were leaking and intake was coated with gunk (crankcase vent hose had been off for few years apparently) i clean everything as best i could assembled and now its worse. IAC unit seems not to move ( i removed from intake engine revs high no movement in IAC with it mounted engine revs high IAC off/bypass hole blocked engine dies instantly thought i knew when i started now i have no clue any ideas would help greatly
truck also backfired and did not before i changed gaskets a vacuum leak would cause backfire maybe failing EDIS pack or cam position sensor cause backfire and vacuum causing idle problem leaning on IAC stuck open
