- Moderator
- #1
Both fuses are good!are 31 and 1 hot accordingly?
C249 circuit 511 no power.Will not pull out of park at ALL, or just in RUN? In between OFF and run, there is the #2 position- will it move out of park there? do we have power from the brake light switch? The bridge resistor and diode on the Shift Lock Actuator would have to be good for it to check ok...
