- 6
- 0
I'm trying to figure out what's going on with the seats in the truck I just bought. The previous owner gave me two driver side seats, one passenger side, a center console (the plastic box) and one center seat console. I'm not sure any of them are actually for this truck.
The driver seat is mounted. The front two bolts appear to be correct, but the rear holes are too far forward of the studs. They drilled and bolted one side down, but the bracket is bent inward. The entire seat is also shifted toward the middle of the truck, when you sit in it the right side of the wheel is about centered with your chest.
The passenger side is a bigger mess. They had an 1/8" plate pop riveted to the floor with the seat bolted to it. The whole thing flopped around so I removed it to fix it properly.
Passenger side floor. What I'm trying to figure out is how to fix this. I'm not sure I even have the correct seats, I seem to recall my '94 having a different release mechanism on the side to tilt it for the rear seat access. That would also explain the seat rails being too short and the width being off. Any thoughts?
