I've decided to go ahead and rebuild the bottom end of Thunder's 460 myself. However, I assume disassembly of a rotating assembly is all pretty similar, my issue is not knowing how to handle the efi top side stuff and electronic connections...and basically the stuff that is there that isn't on a carb'd rig.
I'm also getting confused when looking at parts for compatibility, some things say they're a carb only application and others don't say anything at all. I assumed compatibility would only be in regards to the top end. Any pointers here?
And finally...Tom Monroe put a good book together for carbed 335's and 385's, but here again...I'm looking for something more applicable to the efi side of things. I've got Haynes and Chilton's but they're about as useful as a poopy flavored lollipop. Anyone have any suggestions. And for a bonus, I know Tim from TMI has been a great asset anytime I've had a question on my 335's...anyone out there that would be as easy to talk and as helpful?
Basically, what it comes down to is, I'm uncomfortable with handling the electronics.
And I'm pretty much aiming for a stock rebuild at this time. Anyone have any suggestions on a kit?
So far this is what I know, a bad bearing and scored the crank. I figured that would need to be ground and polished. Beyond that, I'm not sure where to go with it. Suggestions? Advice? At this point, I'm not really sure of myself.
Edit...I'm just in the research stages right now, but plan on doing getting it done this summer.
