95 f-350 7.5 L NO SPARK!!!
Pip signal is good all the way to ignition control module. All wires test at 5 ohms or less. Noid light at injector harness works when turning over engine, showing signal from PCM. No pulse at negative side of coil. Coil tested good according to specs. Ignition control module has been replaced. WHAT IS GOING ON WITH THIS THING?????? HELP!!!!!!
