95 explorer v6
new plugs,alternator,battery,and wires. starter is cranking but cannot get the engine to fire. this happens every so often where the vehicle will not turn over. then we let it sit for a time and the engine turns over...the fuel pump was replaced and you can hear it engage...could it be electrical ?? any help would be appreciated..thank you
Time to hook up the noid lights to see if the injectors are pulsing.
Check the battery cables for corrosion...plus, the starter relay ..........clean and secure..
