95 Explorer Bulb Application chart
Could someone with an 95 Explorer please scan and post the bulb and fuse chart ?
I seem have a contradiction on bulbs
194 or 168 as some manuals say... is NOT correct for this year.
Please hold while I transfer your call...
One moment please...
Hi, my name is Austin; I will be assisting you this afternoon.
Larger please I can hardly read that ;)
and thanks
My Map lights will not accept a 168 bulb and I have an overhead console and it looks like T10 WON'T WORK EITHER
Once the lens is off there is a shiny metal cap with a hole in the middle. The socket looks like it takes a bulb with a contact nub.
could you please scan just the chart area ?
This will bring it closer in view
Maybe he can and maybe he can't, but in either case it sounds like you've tried both bulbs it mentions for the map lights (168 and T10, since I CAN read it)...it probably won't help you much.
*If memory serves, there's two of those lights...would it be possible to remove the bulb from the other side, then match it at a parts store?
Both sockets were empty
Hit CTRL (and) + on your keyboard
CTRL and scroll mouse wheel works too BUT
I want a larger, closer image so I can save it to my harddrive
I can do that for ya! :D
smokey
Hitech hillbilly
I believe when I changed mine there was a adapter type thing the bulb plugged into. That then inserted into the socket. Been a few years since I had it apart.
smokey that sounds like this one may be
Thanks for the larger image..much easier on these old eyes
I wish someone had the parts and Illustrations on CDrom for 89-96 ?;(
