94 f350 turbo injector o-rings
94 7.3 turbo idi
the manifold is filling up with fuel and then leaking all over the place. if i make a sharp turn, it empties all at once. i have replaced the o-rings several times and the injectors are fairly dry. i took it to a dealer 3 times as i thought it was something complex, and they said it was fixed (2 clamps around 2 hoses).
no improvement.
injector pump is dry.
it seems to leak while driving.
when it is parked and running i can not find anything wrong.
could it be pressure related?
the interior of the cab smells like fuel.
everything is factory stock with no mods
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
94 7.3 turbo idi
no improvement.
Check the plastic caps on top of the injectors and the hoses for any kind of cracking. Maybe you can get someone in the truck to put it in drive foot on the brake and give it some gas, while you look under the hood for the leak. Check for any chafeing of the steel fuel lines .
i asked the dealer about ordering the plastic tee's and their response was
" it is a dealer only part and has to be installed by one of their mechanics"
i am going to another dealer saturday as i believe that that comment was BS
d-kuzmen
Master Ford Tech
2,109
79
Connecticut
You are correct.
