- 4
- 0
I'm getting ready to do some part swapping between two '79 bronco's and was wondering about the rear axle. They are both 9" axles one has a spool and the other is open, can I gust pull the center section from each axle and swap them and the shafts with no adjustments or would I need to make shim adjustments. I'd really like to not have to pull the entire axle if i don't need to.
