When my truck warms up the transmission shifts really hard. What could be causing it?
Jan 15, 2009 #1 benthere84 The Beast 2 0 Indiana When my truck warms up the transmission shifts really hard. What could be causing it?
Jan 16, 2009 Moderator #3 blacksnapon Moderator Staff member 9,461 301 waynesville,mo. You might try changing the lube. When its warm, the fluid will thin out somewhat. Make sure your clutch is working properly as well.
Jan 28, 2009 #4 benthere84 The Beast 2 0 Indiana Lube How would I change the lube? Is there a drain hole or a fill cap?
